Oil Pressure Check Valve
lynndiwagon
I've had the same problem with my remote oil tank holding pressure as I have read about on this forum. I just returned from the Lake and noticed that after 3 months of setting the tank still had presssure. I think this is what is causing the BIG SMOKE problem when starting. The engine is a 1999, 135 HP, Mercury carb. model, sn OG804612. I have searched Mercury and other parts outlets for the part numbers for the check valves with no luck. Please help me find the part numbers and place to buy. Thanks. I have a book that shows the valves but not the part numbers. Thanks.
rabidfish
Re: Oil Pressure Check Valve
If the check valve you are looking for is the one in the block, that pressurizes the remote oil resevoir... The part # 21-878105-1
lynndiwagon
Thank you very much....yes I think that is the one I will need.
