I am cleaning and prepping a block from a V4 crossflow.<br />I'm calling the highest cyl, #1 and the lowest #4.<br />There is a small passage in the bottom of cylinder 1. <br />Also there is a small passage with a brass insert in the block where the center crank bearing will be located.<br />What are these 2 passages for????<br />Are they supposed to be linked???<br />Should air pass through these???<br /><br />thanks
