Oil Lubed Hubs
shinytopgeezer
I've only owned two boats and trailers over the years and always enjoyed them. All had standard grease hubs. I've also owned several over the road tractors and trailers. All those had oil lubed hubs. Never had a failure or maintanence issues (except the Mack! ugh, it broke me.). Anyway, I was looking at EZLoaders web sight the other day and noticed they have oil lubed hubs as a option! Has anyone upgraded their own trailers to these hubs? And who makes the conversions? With the RIGHT seals should be ezy-pzy! Thanks in advance. Great web site guys. We "vicarious" boaters are depending on you!
alldodge
My new trailer has oil bath and made by Dexter
Searching web for "oil bath hub conversion kit" and can find several. Here is Kodiak kit
Figure as long as the spindles surfaces are in good shape they should have no issues
dwco5051
I have had both sixty some years ago. Had a couple of bearing failures (BIG $$$) with both. A seal failure on a packed grease bearing will usually give some visual signs with grease slung out from the bearing. A failure on an oil bath can cause failure within a hundred miles. I live only a few miles from interstate 80 and our local fire department handles at least one or two trailer fires a month and I think that the oil accelerates a fire caused by a hung up slack adjuster. Packing just the trailer axles was an all day job if you owned the equipment. Back in my days every stop for meals or fuel also was a complete walk around with the tire billy, feel all the hubs for heat (before hand held IR guns), and check oil level in sight glass. I can sit in a restaurant today and never see a driver do this either right after stopping or before leaving. If you drive in flip flops wearing shorts you have to rush back to that air conditioned cab with your automatic transmission.
Sealed grease packed roller bearings are good enough for the railroad and they are also good enough for my boat and light equipment trailers. And yes many companies including Dexter make wet bath bearing kits.
Stinnett21
My boat trailer was new in 2003 with UFP oil bath hubs. They lasted 15 seasons. Boat was always towed, often 3 hour trips to lake and back. Boat had 1,300 hours when the hubs were redone in 2019. I went back with grease hubs only because the spindle surfaces were getting worn.
shinytopgeezer
Thanks all for the replies! Good reading. Thanks for the link alldodge, very informative. And Stinnett21, your history with the oilbath was great. The worn spindle surface must've been on the seal surface? Did you ever have water in the hubs? It's so common with the greasers I'm curious. Also odd since the lower units on the drives spend alot more time under water than the trailer hubs and seldom have water problems. And the proplers spin alot faster than the trailer wheels!!! Well, except for Scotts!!!😃
