Oil lines replacement ???
Eddyhifi
Hi everyone, do i have to change the oil lines base on years of use? does the inside hole of the lines from oil pump to cilinders changes diameter with the years?? I want to make sure all of them are delivering the right amount of oil.thanks:rolleyes:
Capt Ken
Re: Oil lines replacement ???
If they are not leaking, leave them alone. Check the ends to be sure they aren't splitting. If so, then replace them.
99yam40
You could flush the lines and check valves, test check valves, along with draining the tanks and cleaning them and then run premix while you measure the lines out put to make sure it all meets spec. Should all be in the Service manual
Water /sludge in tanks can end up in the system if you do not take care of it
