Oil leaking
Tony305
I have a 1988 28hp Johnson that has pin coming out of a hole under the exhaust. It smells like gas also. Here is a picture. I'm new to the boat owner world and would like to know how much this will end up costing me.
Mohawkmtrs
It's unburnt fuel/oil coming out of the exhaust section drain hole. Totally normal. Take it out and run it wide open for a while to clear.
If it's a new to your outboard, replace the water pump impeller and check/change the gearcase oil.
Tony305
Thank you for assistance I will do what you said and post results.
