Oil leak under foot
cbillingsley
I know this is a very popular topic, I have seen many conversations on this very subject, so I thought one more would not hurt. I fished a tournament Sat, night, 9 hours on the water, Sunday morning I went to clean up the boat and noticed a small puddle under my foot, it was an oil/water mix, and I believe it did have that oily smell, I use my boat weekly all year, so it is not un-burned stuff. I am not very educated on outboard motors, (225 HO Johnson), but I am thinking it may be a seal issue, can somebody confirm or dispute? I have some pictures that tell the story better. I sincerely appreciate any help!
jimmbo
You say it has "that oily smell". Well engine oil/gas has one kind of smell, gear oil has a very offensive smell(at least to me).
Remove the drain plug on the case and see if what drains out looks milky too. If so, the gearcase has leaky seals. It might just be the gaskets on the drain and vent screws, or the case has to be resealed. A dealer can do a pressure and a vacuum test to verify if there is a leak
I suspect the seals under the water pump are letting water from the pump under pressure into the case, and the resulting pressure is pushing the emulsion out the shift shaft seal, but that is only my guess
cbillingsley
Thanks for the reply Jimmbo, when i get home i will smell the leak again Will post Tuesday
cbillingsley
went and took another look yesterday afternoon, the smell was strong, gear oil strong, plus i had a little linear play in prop that i would swear was not there three days ago.
