oil leak 76' 70hp seahorse
funkenfresh
another problem has come up.. thick oil substance is leaking out from a centre hole in the back of the leg... :mad: whats happened?!?!!??! HELP!
Mas
Re: oil leak 76' 70hp seahorse
Likely, your engine is running slightly rich. Are you using 50:1 mix? Many 2-strokes will drip out some "black gunk" after running. Check your lower unit lube to ensure it isn't part of the problem.
MAS
