Oil in U-joint bellow!
Wolf pack
After 5 years I removed my u joint bellow and found about 8 ounces of oil
In it . I took it to my Volvo mechanic & he thought it my be coming from the engine side. I thought it's coming from the drive. He's going to replace the seal behind the u joint on the upper housing of the drive. Anyone have similar issues . I have a 280 drive with a 1996 5.7 GL.
Don S
Re: Oil in U-joint bellow!
Tlhere is no way in the world for the engine to leak oil into the bellows. You should be looking for a Volvo mechanic, because you don't have one if he said that.
Not sure about you having a 280 drive. Volvo stopped making the 280 in 1984 (eight four) .
Might want to post some pictures of your drive, and engine and find numbers on both.
Wolf pack
Thanks for the reply Don. I'm sure my mechanic was pulling
My leg , he's sort of a joker. I'm pretty sure the oil leak is from
the upper housing seal behind the u joint.
In 1996 I repowered the boat and just replaced the engine and not the
280 drive. I think I exchanged the bell housing from the old engine to
the new engine to make the fit. Boat is a 1980 Bayliner and is 23 feet.
ENSIGN
It's lucky you found it before the drive was destroyed!
