Re: Oil in my bellows
That must be outdrive oil in the bellows, you need to replace input shaft seal. I'd try get it pressure/vacuum tested after seal replacement, so you know its good.
You'll need bellows adhesive to reinstall drive. I don't think you can get engine oil in the bellows, (well the exhuast bellows you could)
