oil gas mixture
brendajoyce
i just bought a boat with a 1992 9.9 yamaha motor on it can someone please explain fuel mixture , how much oil to gallon of gas
JB
Re: oil gas mixture
Hi, brendajoyce.
Welcome to iboats. :)
Your engine calls for a 50:1 gas to oil ratio. If you are using a common 6 gallon tank, put a pint of TC-W3 rated outboard oil in there and you will have a 48:1 mix. That is what is most of us do because it is so easy and doesn't leave us with partially full containers.
99yam40
Re: oil gas mixture
If you are trying to mix a smaller amount of fuel, you can pick up a measuring bottle at most marine outlet stores that is marked in different ratios and for different gallons and ounces.
Or just use math to figure what you need 16 oz to 6 gals, 8 oz to 3 gals, 4 oz to 1.5 gals, etc. are all 50:1
guitarguy15
Re: oil gas mixture
Its all good bro. I figured its pretty similar so it would be a good reference point
