Oil for Mercury 60HP Bigfoot
Shtukscoda
Hi, i was wondering if anyone could tell what kind of oil i would need to do an oil change. Also if it would need to be synthetic or semi synthetic or not. Thanks
Fun Times
Re: Oil for Mercury 60HP Bigfoot
Hi there Shtukscoda, By chance, what year is your outboard and just to clarify, you have a 4 stroke engine Correct? Engine serial number would be better if possible.
Also are you going to want to change out the lower gear housing oil as well?
Shtukscoda
Hi i can check the serial number when i get off work, but yes it is a four stroke, and it is a 2013.
ondarvr
If its a 2013 you should have the manual, it will have all the information you need to choose an oil for the motor and the lower unit.
