oil filter
Lucky Penny
I have noticed over time that some folk warn others away from using FRAM oil filters. There must have been some problems with them. Why not use FRAM filters?
KaGee
Re: oil filter
The primary shortcoming of this study is the small sampling size. I only tested the Ford 5.0L filter. Some brand names use different manufacturers for different applications. Another shortcoming is the lack of testing of the filter element media itself. Unfortunately I have neither the time nor resources to do this.
Like anything else... take it for what it's worth. I've never experienced a problem with Fram in the past. Currently using K&N in my boat.
Lou C
Re: oil filter
I'd love to find out, is there really an advantage in using 'marine' filters vs regular car filters, I do use the Sierra Marine ones on my V-6, but in the OMC manual they even recommend the Purolator and AC filters, in addition to their own. I have heard that marine filters flow more, maybe filter less, to deal with the sustained high RPM use, any thoughts on this?
whywhyzed
Banned
Re: oil filter
Easy to answer this question yourself with the proper tools.
Every mechanic or DIY'er must have a filter cutter or you are not doing the job properly IMO:
We get our students at the school where I work to cut EVERY filter that comes off every engine, transmission, and hydraulic system. Both to inspect for metal, dirt and other indicators of problems developing in a machine and out of environmental responsibility (we recycle the steel and crush the oil out of the media with a press). I couldn't sleep nights throwing filters in the landfill full of oil.
After you cut a few, you'll see why Fram, and most other auto parts store products are inferior.
As far as automotive/marine engine oil filters, this is the best of all the brands we've ever cut open. Pleat count, pleat separators glued on, spiral roving, steel dipped and glued end caps, cast aluminum head, inertia welded can seam..... nice filter! and the threads are clean! On a lot of store bought filters, if you take a white cloth, and wipe the threads....ugh... dirt.
All that said: My boat has a Fram filter on it.
It's a boat engine, who cares...
We have some diesels worth $75,000 at work.... we take filtration seriously there
I buy the Donaldson's when it occurs to me but the only place to get them is at a Caterpillar dealer..not real handy for me... oddly the Donaldson is about the same price as the Fram
