Oil filter for Mercruiser 135hp 3.0L 2007 engine
thefullmonty
I have scoured the manual and can't find the OEM part number for the oil filter. I want to change the oil before I put it up for the winter. I know I can cross reference the original part number to a compatible oil filter, but I can't find the original mercruiser part number. I hope someone can help me out. I have a Suntracker Party hut 30 with a 2007 Mercruiser 135hp 3.0L inboard/outboard.
elkhunter338
Master Chief Petty Officer
Re: Oil filter for Mercruiser 135hp 3.0L 2007 engine
It is just a standard old chevy oil filter for a 4 or 6 cylinder, probably around 1960-70 or even into the 80's and 90's.
I have a 2007 135 hp 3.0L chevy engine and I run a xg30 Fram oil filter. I would stay away from the ultra cheap filters.
But the marine filter that came on the engine when I bought it was not a great looking filter after I cut it apart. Paper was nothing special, looked just like a cheap automotive filter.
billbayliner
Re: 3.0, 5.0, 5.7 oil filter #
the filter thread is 13/16 x 16 NPT. The o-ring gasket has diameter of 3.25", it runs along the
outside of the top of the filter.
Short length filters are:
Fram PH30
supertech st30
wix51046, wix51069, 51086, 51087
napa 1046,1086,1087
purolator per12, per49,
acdelco pf12, pf2525,
motorcraft FL10, FL775
sierra 18-7824
The long lengths are:
Mobil m1-302
Fram hp4, ph5, ph13, ph373
wix51060-51061-51794
napa1060-1061-1069
per40,
per84pf11, pf35 pf1218, (pf832-932)FL308
sierra 18-7877
zbnutcase
I always install the long filter if theres room for it. 'nutcase
Ayuh,... If,.. Pretty Big word,.. Ain't it,..??
I agree though....;)
I use the Napa/ Wix myself....
