Re: Oil drain plug over-tightened
If there is any usable slot in the head of the plug, a big screwdriver that really fits the slot and that is squarely ground with absolutely no rounding off of the edges or corners (as new in other words) and which will accept a small spanner on the shaft.
Start with a sharp tap, that might loosen the grip on the screw a bit . It often helps to slightly tighten a screw before undoing it as well.
Support the engine firmly lying on its side, put all your weight on the screwdriver and try to turn the screw sharply with the spanner on the driver.
Heat might help, a kettle full of boiling water over the gearcase first will expand the alloy of the case away from the steel screw.
A freezer spray, the stuff plumbers use to freeze pipes, directed at the screw head is another trick to try.
If that does not work or the screw head really is too far gone to attempt that maybe an "easy out" will do the trick but drilling the pilot hole in the screw really needs the engine clamped down firmly on a drilling machine, and a broken off "easy out" will double the trouble.
