Oil Change on my 4.3L
e-dubKC
I bought a 1987 Marlin last summer that has a 4.3L with Cobra outdrive. Long story short, when I bought it the guy I bought it from told me he already had it out and it was lake ready. So, I promptly ran it out to lthe lake and smoked the engine... literally. The exhaust bellows cooked and put off as much smoke as a tire fire! No joke. I later figured out that TWO expansion plugs were completely out. I fixed the engine and it was running fine when I last ran it. Here's how that event applies to today's question: In the process of smoking the engine and thusly cooking the exhaust bellows, I also melted down the two valves attatched to the valve covers (I'm assuming those are PCV valves.). Althought I had those inlets plugged and covered with shop rags over the winter, it appears that water has still made its way into my oil. The oil is milky. So, here's what I plan on doing and any advice pro or con is appreciated: I am going to drain the oil and filter directly into the space below the engine and let it drain for a few days into a bucket beneath the transom drain hole. I will add a regular automotive engine flush and use according to the directions. Then, I'll replace with the proper oil... is 10W40 correct for the 4.3L? And, here's my real question... where is the dang drain plug located? The whole pan feels smooth. Would it be easier to use an oil vac to remove it? Thanks in advance for any response.
Don S
Re: Oil Change on my 4.3L
How much water in the oil? A cup of water or a couple of gallons? If the core plugs were popped, you can bet the block is probably cracked under the intake manifold.
Very common problem in the spring of the year around here, and believing what a seller says is the first mistake you made. He got the gold mine (your money) you got the shaft.
tpenfield
Water may be getting into the oil for reasons other than what you described. . .
. . . as far as changing the oil, it is often better to suck the oil (and water) out than it is to drain it. (oil plug may be on the side of the pan).
BTW - welcome to iBoats. lots of information here.
e-dubKC
Hey Don, I was hoping you'd reply...
There was no water in the oil when I parked it for the winter. The expansion plug thing happened early last summer and ran fine after that, after after diagnosing and remedying other issues related to vulcanized exhaust bellows.
Based on that, I can only assume the water got in through the PCV valve hole that I found uncovered. We've had LOTS of rain here in Kansas City lately too. Can't tell how much water is in there, though. It's pretty milky though.
I'm not giving up on this old boat just yet... gonna try and turn my shaft into another gold mine!
