OEM Temp Gauge
greekfreek
2010 Merc 3.0L MPI WEC, catalyst engine. The dash temp gauge reads around 175-180 during normal running. With 2 different IR Temp guns it reads 160 - 165 at thermostat housing and temp sensor area. Is it normal to have this type of inaccuracy as long as I know the temp diff ??
NYBo
Re: OEM Temp Gauge
The temperature sending unit for the gauge is in direct contact with the coolant, so I'm not surprised it reads higher.
cr2k
Re: OEM Temp Gauge
The only thing less reliable then a marine temp gauge is the fuel gauge.
