What kind of car engine? Something fairly new? If the car engine is fairly new its probably in the 9.0-9.5:1 compression range. At that range on a good engine you should see about 150 PSI or so. If the car engine is newer, 10+ compression is common now days in which case you would see about 180+ psi
I suspect your gauge is not reading correctly.
If its running that good I would be more concerned about your prop. You need to be turning 4500 - 5500 RPM with that engine. What size is the prop? what pitch? That should give you some indication if the engine is solid or not. If your already running a low pitched prop designed for pontoon use and you're still only turning 3700 she's sick.
If your turning a higher pitched prop designed for a runabout that will do 30 mph and your turning it to 3700 on a heavy pontoon that engine might be running fine.
make sense?
