Octane for Mariner 135 V6
xperksx22
Hey I have a Mariner 135 I usually run 91 octane in it and it runs well. 91 octane is hard to find in my area and it is becoming inconvenient to use. Can anyone recommend another octane that will be okay to run and will not cause me any problems ? Thanks
79Glastron
Re: Octane for Mariner 135 V6
I run my 135 with 89 octane and sea foam. I believe the book says you need a minimum of 85 octane.
wired247
Buy the cheapest gas they sell at the gas station for your 135. Its a low compression motor. 91 is overkill and doesn't make it run better. If anything, burning slower burning ( higher octane ) gas in a motor that does not need it will make it run worse.
If you store it over the winter with gas in it make sure to use some stabil or fill that last tank full with non ethanol gas.
bgc
Ensign
The higher the octane, "the slower the burn",........ When the stroke is 1.5", a faster burn without knocking would be advantageous....
I loose 2 knots with 89 octane vs. 87.
quicktach
Drop down to "Regular" gas....it should be OK. Use good quality outboard oil. Additives not necessary, including Seafoam.
xperksx22
Thanks guys ran 89 on Sunday and it ran great. 89 is much more available than 91 so it is a "Win-Win"
