Re: Oak Red or White?
Manipulator,<br />Red Oak and White Oak are two different animals.BTW, the color of the wood (red or white) doesn't have anything to do with the species of oak. I've seen very reddish white oak and very white (blonde) red oak.<br /> <br />Red oak has large pores in it that make it ideal for furniture-making (soaks up stain and other surface finishes). Unfortunately, that's also what makes it poor for marine construction purposes (soaks up water and will rot very quickly).<br /><br />White oak, on the other hand, is much denser and has very small pores that won't soak up water easily. Not to say that it won't, all wood will absord water to some extent. If you apply a sealer such as blond shellac, then your finish coat of your choice (varnish, polyurethane, etc), you won't have a problem with white oak. <br /><br />I built an anchor pulpit three years ago out of white oak and it's just a pretty now as it was then. It's withstood three seasons of harsh New England sea's and weather. One last thought, the USS Constitution (Old Ironsides) is built from white oak planks, and it's two hundred years old!
