O-Ring/Washer for lube change screws - 1990 Cobra
dodge1930
Hi,
OMC 1990 3.0L Cobra, (302BMRPWS)
Need to know the size and type of O-Ring/washer, used when changing the lube in the outdrive.(Two bottom screws)
Locally I've been given two different size from two different dealers.
So which is the right one?
Rubber O-Ring 11mm OD 8mmID
Plastic Flat 15mm OD 9mm ID
Thanks
Steve
Reinell-BRXL-191
Re: O-Ring/Washer for lube change screws - 1990 Cobra
You are being given 2 different sizes, because you need both.. the upper fill plug requires the O-ring - the lower drain plug requires the washer..
