tjgatorland
Thread starter- Joined
- Jul 1, 2010
- 5
Good morning gentlemen. I wonder if I may trouble you for the timing settings for my 2001 18hp 2 stroke. I saw the 9.9 and 15 posted but not the 18. I would imagine they are very similar but since this isn't horseshoes or hand grenades I thought I better ask. I got my compression gage out and thought I would check that first then check my timing settings. I bought this new in 01 along with a 16.5 flat bottom smokercraft aluminum jon boat. For the last 20 years, I have never pulled it more than two times to crank it. I run it inshore here in N.E. FL. One day I'll get around to changing the factory impellar on it. Last time out it wouldn't ever plane out. It ran a fast idle with the tiller turned to the rabbit. I would have the wind and the tide behind me and it just would not get up and go. I did for unrelated reasons used a different tank and fuel hose that day. I cleaned the carb real good and put new 5/16 lines under the cowl and it ran on the hose fine. It would rev up in nuetral fine. Back to the water and same thing. I've cleaned that carb so many times I bought a new one from amazon. Back to the water and same thing. Got home on the muffs to flush it and run and rev up fine. I have taped all the fuel hose fittings and primer bulb ends in case it's sucking some air and about to check compression and hook up my spark tester. Then I thought I'd check the timing. Any ideas? I have read nearly every post you guys have done and y'all don't miss a thing!!! I'm about out of ideas. I'm holding out on that $30 quick connect fuel fitting that goes through the front of the lower cover. Call me cheap but that should be against the law!!!
