ns 50d2 runs rougth
frmach
motor startes on first turn of stater and has smooth idle. runs rough ar 1/2 throttle and will smouth out some ar full throttle
New plugs and fuel. any ideas?
Sea Rider
Are you using any carbon remover product sprayed through carbs or mixed with the fuel in tank ?
Happy Boating
frmach
no. I have not tried that. Will Sea Foam work for that?
Sea Rider
Is that engine used in fresh or salt water, would you say has low, medium high or high hours of use ? Sea Foam diluted on fuel will take much longer to work compared to any Carbon Remover product such as OMC Carbon Guard, CRC Engine Tune Up sprayed pure through carbs with engine ON as per product instructions.
Happy Boating
