Now it wont even run
cobweb
Hi, I got my Chrysler 70 HP to run, went to the lake and had to spray fuel into plug, then it fired right up at, 3 quarter throttle, not to bad, but when you put her full. it would completely die, brought it home and took bottom off carbs, found sand and dirt in bowl, sprayed out as good as possible with carb cleaner and put back together, now it will only run till the fuel burns out of the plug Please.. anybody
roscoe
Re: Now it wont even run
suspect the dirt got into the jet and plugged it up.
Time for a complete carb disassembly and rebuild.
cobweb
Got it up and running, would like to get a little more power out of it now, can you tell me how to adjust carbs and what my fuel mixture should be,Thanks
steelespike
You need to be patient waitng for replys especially around the holidays.2 identical posts get confusing.
Check your other post for more info.
