Texasmark
- Dec 20, 2005
- 15,016
Had a response I made to a V6 temp problem questioned. I started back tracking to verify what I said and pulled out my 3 cyl 90 hp service manual. It covers '94 thru '98 and supposedly above but I don't know how long that was.
Anyway I start differentiating between the use of tan and tan/lt. blue color codes on the warning circuit wiring between OT sensor, low oil sensor, and the warning horn.
I know temp is a solid alarm and oil is a beep. Seems to me you need some electronics to perform that so one would look to the "warning module" to perform that function.
There is a separate section that describes the warning system, with schematic and that includes a module.
If I go to the engine schematics however, for the '94 thru '96 engines they show one, but for the '97 and '98 there is none.
So the question is, how do you get two different warning indications from a circuit that has both warning sources tied together and connected to the low side of the horn?
Mark
Fine, but on the later engines
Mark
