Re: not reaching full operating temp?
my starboard eng runs at 170-175 f,
my port eng only runs at 150-155 f and burns significantly more fuel
They do use more fuel at lower temps. How much for just 20?, I don't know. Assuming you plan on doing your own maintenance now and in the future, I would suggest the
TECH MATE Scan Tool only 400 and does everything you need it to do, and is upgradable if you get an even newer engine in the years to come. If money isn't an object, the software for the laptop is great, but for once in a while (They don't break that often) the scan tool will tell you the same thing, just takes a little longer to scroll and read.
The Tech Mate and the OEM service manuals, a DVM, fuel pressure gauges for the high pressure EFI systems and you wil be set to go (for 99% or the problems anyway).
