Not pumping water
I just got done installing a new fuel filter and I started the 1998 Yamaha 25 hp up, I immediately realized there was not any water coming out the pee hole. I shut off the motor quickly and checked muffs to make sure they were on good. Tried again and same issue. The motor has sat for 5 weeks or so without being ran but pumped water fine last time I was out. Is it possible for the impeller to fail that fast? Any pointers for a first time lower unit drop? Thanks for any suggestions.
99yam40
Re: Not pumping water
may want check to see if tell tail is plugged, bugs like to build nests in them
Well, just got back in from outside. It was making me crazy not knowing the problem, so I went out with a flashlight and some weed whacker string. I pushed the string a few times with no blockage, the last time i went in as far as it would let me, and still nothing happened. I started the motor yet again and noticed water from the exhaust when suddenly I was getting a shower from the tell-tale, thank you..saved me a restless night.
