Not holding idle 96 ocean pro
Flye
JUST got my 96 200 Ocean Pro rebuilt. In third hour of break in.
after 3-4 mins of idle either in gear ot out, it sneezes and/or coughs a couple of times, rpms start to drop, and then it'll usually cut off.
Thanks for any guidance on the idle problem. Still have the oil doubled up for break-in, so I suppose there is an outside chance that THAT could be affecting plugs at low RPM.
D
Flye
Re: Not holding idle 96 ocean pro
Just trying to get issue back on top. so far, no answers/suggestions. Thanks
bktheking
Is this something you did yourself or was it done by a marina/boat dealer?
Flye
no, was rebuilt by professional rebuild company.
tashasdaddy
check for fuel line leak, vent open on fuel tank.
daselbee
Pump the primer bulb when it begins to die. See if it picks up. Sounds like (because you mention 3 - 4 mins), that the engine has emptied it's carb bowls and has run out of gas.
If so, new fuel pump.
Why didn't you answer my question to you in your other post?
