Re: Not getting gas to the cylinders
Here's from the start, we got the boat from my brother, it's probably only been in the water maybe 6 times, it propbably only has about 40 hours on it.
Bill, my husband, pulled the cover off and it shines like new in there. My brother tore all the wiring out and was re-working the wiring. After he thought he had it hooked up the right way it wouldn't start so he gave up now we have the boat. The wiring in the boat, not the engines wiring. New switch, gauges and throttle control. The wiring diagram he used was not correct, Bill went by the Seloc Outboards 1990-00 Repair Manual and re-wired it. Now all seems to be working, he has fire, engine spins, he can hear the enricher clicking when he pushes the choke button. The fuel pump is pumping gas to the top. He can choke it all day and he's not getting a sputter or a glimps of life from it. It's like it's not getting fuel to the cylinders. He knows those two lines were leaking, but he put a good amount of pressure on the bulb before they started to leak. He found one hose that was bad and replaced it and it didn't matter. He intends to replace them all, but at this point he doesn't see anything else leaking. He thinks he should at least be getting a sputter of life from it. The top two plugs look just like they did when he took them out of the box and put them in. It seems like no gas is making it from the carburators. He's had people tell him that one little thing can screw up the whole works so messing with it is a little intimidating. He can rip a car, truck, mower apart with no problem. Can it be that the enricher id bad, that it clicks, but just doesn't work because the boat sat all that time?
