Re: Not firing one cylinder
Beer sounds good to me! Where do I pick up the ticket?<br /><br />I feel 90% confident that it's the seals. With that ignition system (call it a trigger or ignition driver), if you are losing spark on one cylinder it's either the spark plug or something's putting the fire out. If you've put a known good plug in the hole, that only leave the other option. So, what can put the fire out? Lean fuel mixture? Yes, but the carb that feeds #4 also feeds #3, and #3 is firing. What else? damaged reed? VERY unlikely. I see about 1 broken reed a year, and that's mostly on Johnrudes of high hp. Are you getting any 'spitting back' from the bottom carb that's not on the top carb? What else? Water can stop a cylinder firing. And where can water enter an engine? through the bottom seals and it will only affect the bottom cylinder. <br /><br />When you eliminate the likely whatever is left, no matter how unlikely, MUST be the problem. (Sherlock Holmes, I think)<br /><br />Chris..............
