Re: Not firing one cylinder
Concur, you MUST determine whether or not that cylinder is sparking under load. You can have a decent looking spark with the plug laid out on the block, but under compression you may find the spark is blown out.<br /><br />Not so likely on the Lightning Energizer ign, but you are trying to determine, via a progressive troubleshooting process, what your problem is.<br /><br />If you don't know whether it sparks or not under compression, you don't have enough information to determine whether to proceed to powerhead removal or other courses of action.<br /><br />The idea of the 'sparky' tester is a good idea, they're hard to see in the sunlite but show up good in the evening or in the shade. My suggestion of a timing lite will work any time and will definitely show you if you have fire at the spark plug, under running conditions.<br /><br />We're not saying it's impossible for #4 to not have spark if the other 3 do, but it's highly unlikely. Still you need to check it out to be sure.<br /><br />Another good point made is, if the plug is being washed clean of carbon etc, water does a very good job of doing that! <br /><br />Many of us have Been There, Done That and are just trying to get to the root of the problem in a logical manner.<br /><br />HTH and Good Luck...........ed
