Not finding some parts for 33hp johnson?
matt9923
I don't see some parts for the 33hp Johnson on Iboats. It doesn't even list the 33hp for the thermostat and fuel pump. Where can i find the part numbers for these parts. Even on ebay i see everything for all other HPs but not the 33s?
Thanks Matt
CATransplant
Re: Not finding some parts for 33hp johnson?
Go to:
http://shop2.evinrude.com
You can look up and order OEM parts from that site, and see parts blowups.
iboats.com sells mainly the Sierra line, and it's hardly a complete line, although there are some real savings for the parts they carry.
matt9923
Go to:
how do i find my model number? where is it?
tashasdaddy
where it says Evinrude on the top left, click the drop down menu, select johnson, and follow prompts. what year is your 33hp, this only goes back to 1968. if it is older than 1968, you need a parts and service manual, and will need to contact a dealer. manuals http://www.outboardbooks.com/
also http://www.laingsoutboards.com/ , carries a lot of parts for older motors. if you do not see it on the site, call Jeff directly, very good to work with, and knows his stuff.
matt9923
cool, where is the model number on my motor cause i see it has 4 different models for the 33hp 1970 model? witch is mine? are they the same.
tashasdaddy
either transom bracket or on the freeze plug on the block. they are basically the same, long shaft, short shaft, a few minor differences.
F_R
33 horsepower motors don't have thermostats. No wonder you can't find one.
matt9923
tashasdaddy
and decent price.
