Not charging.
war623
I have a 2001 Evinrude 90hp and it is not charging, I am trying to find the regulator/rectifier on the motor but I am having trouble locating it. Can anyone help?
Re: Not charging.
Put your finger on the starter solenoid terminal that has the big red cable that runs to the positive post on the battery. Note that there is also a smaller red wire on that terminal. Follow that wire back to the regulator/rectifier.
war623
Re: Not charging.
I found the red wire okay but it goes into a harness and branches out and I can not see where it comes out.
boobie
Re: Not charging.
Got a model# ?? If this is a DI mtr the charging system is part of the EMM.
war623
Re: Not charging.
The model # is RE90FPLSIFIt and is a DFI 2 stroke.
boobie
Re: Not charging.
Read post # 4 again. You should take this into a dlr and have a laptop put on it and see what codes come up. You could also have a bad stator.
war623
Re: Not charging.
After researching it further, I think you are right. I did post the wrong model number and it should have been E90FPLSIF. I cannot find a part called a Regulator/Rectifier listed so it must be in the stator. I was hoping you were wrong as I did not want to replace the stator.
boobie
Re: Not charging.
As said before the reg/rect is part of the EMM.
boobie
Re: Not charging.
Maybe, maybe not. As i said before, have it checked out on a laptop. The lap top will check voltages at different points.
war623
Re: Not charging.
No errors found except the air temperature which was unhooked. Is there a possibility that it could be a fuse?
boobie
Re: Not charging.
You may want to check all the fuses in the PDP panal.
war623
Re: Not charging.
All fuses were good but their are some relays mounted in with the fuses. Would any of these be a possibility? I have ordered a manual for this and maybe I can find something in there.
war623
Re: Not charging.
It is in the stator. Now to change out the stator. Not looking forward to that.
