not charging
jhawk73
1988 mercruiser 5.0 Chevy v8, alpha 1 out drive. volt gauge on dash reads battery voltage running or not, ammeter on alternator output wire shows nothing. I am unfamiliar with marine alternators, what do the other wires do? What is the best way to isolate the problem?
Silvertip
Honorary Supreme Mariner
Re: not charging
The best way to start is to remove the alternator and have any local auto store test it for you. If it tests good, then go after wiring. Starting with the alternator saves time and frustration -- especially if you are not familiar with electrical systems.
Searay87
Re: not charging
Not sure what your alternator looks like but you can start by looking at the pictures on this site. If it's not this one then I'm sure you can find yours there.
http://www.dbelectrical.com/p-3611-...o-marine-mando-alternator-293-18-amn0002.aspx
As for isolating the problem, I agree with the previous post. If you haven't tampered with the wiring then you most likely have a bad alternator. Before you remove it and just to confirm a dead alternator, run your engine at 1500 RPM. Measure the voltage directly across the terminals of your battery. If you aren't measuring > 13 volts then you have a problem. You can also measure the voltage output at your alternator. Find the right diagram. Put the positive on the alternator output, put the negative lead on ground or clip it to the negative post on your battery. If the alternator is good you'll be measuring > 13 volts. Good luck.
cr2k
Re: not charging
an amp meter will only work is series so you have to disconnect the wire to add it in unless you have one that clamps around the wire to measure current. Plus if your battery is charged the alternator will not be putting out amps.
A good charging alt should put out closer to 14v then 13, but it should be over 13v since a fully charged battery is about 12.6+
