I have a 1998 Mercury 25EH #06597261. I bought it at a state surplus auction two years ago and it was a game and fish motor. It looked new with no scratches or anything. Even the factory paint was still on the skeg. It was missing the prop and starter. I still don't have a starter. It looked like they just used it for parts.
The problems:
1. It runs rough and always has.
2. It obviously is not burning all the fuel. Smokes heavily and I can smell the unburned fuel
3. It doesn't pump a steady stream of water through the pump.
4. It has a sludge/oil mix coming out around the prop. I'm assuming unburned fuel.
I have done a lot to it, so it may be hard to diagnose. Nothing I have done has made any change in performance.
1. New plugs. I also checked for a good spark.
2. Rebuilt the carb with no change at all. I have rebuilt carbs on many machines and never had any problems.
3. Cleaned the connections and every wire.
4. Replaced the impeller. I installed it turning clockwise and checked every wing. No change.
5. The pms screw is turned out 1/2 turn like I got it. That is the only way it will run, unless fully closed.
This is my fourth outboard and none have acted like this. I only use ethanol free gas and use Seafoam every tank. I have tried evertthing I know to do. Mix is 50:1. I really don't know much about 2 strokes. Could it have got too hot and warped something? Thanks in advance.
The problems:
