Is that board back there normal? It looks normal from the outside.
W woody619 Petty Officer 2nd Class Joined Mar 13, 2010 Messages 107 Oct 8, 2010 #1 Is that board back there normal? It looks normal from the outside.
Alpheus Lieutenant Commander Joined Aug 3, 2009 Messages 1,759 Oct 8, 2010 #2 Re: Normal for transom? You mean the outside where you cant see it? You think it would be glassed over to prevent getting wet and rotting...
Bondo Moderator Staff member Joined Apr 17, 2002 Messages 71,519 Oct 8, 2010 #3 Re: Normal for transom? Ayuh,.... Looks normal on the inside too...
W woody619 Petty Officer 2nd Class Joined Mar 13, 2010 Messages 107 Oct 8, 2010 #4 Re: Normal for transom? Thanks, no it looks fine from the outside. Was asking about in the bilge side. Trying to look for other stuff that's wrong with this. Thanks
zbnutcase Commander Joined Sep 19, 2009 Messages 2,055 Oct 8, 2010 #5 Re: Normal for transom? Have seen quite a few boats built like that.
H HT32BSX115 Supreme Mariner Joined Dec 8, 2005 Messages 10,083 Oct 8, 2010 #6 Re: Normal for transom? It's very common..... A LOT of boat builders don't seal the bilge area very well. As long as it lasts the length of the warranty, they're "good"! If you ever have the engine out, you can re-glass & seal it all up and paint it! Before: After:
