Re: Normal - Expected Sway?
Dunaruna, no bad day, just dumbfounded with the responses to enable someone to more safely break the law. Is there such a situation?<br /><br />A while ago in Australia it was illegal to tow above 90kmph. This has since changes and you can now tow at the signposted speeds. <br /><br />But should you?<br /><br />Sure you can, if all appropriate and responsible conditions are met, like tyres correctly inflated (and appropriate type), trailer in good condition, ratio of towing vehicle to towed vehicle weights appropriate (brakes if required!!), tongue weight within correct tolerances, driver is suitably experienced, etc etc. The list goes on.<br /><br />But what normally happens is the driver jumps into their vehicle, which now weighs 3 ton instead of 1.5 ton, and wonders why it feels different.<br /><br />Dunaruna is right. Get into a sway at 65, or 70, or 75 with a load that does not have it's own brakes, and most times be prepared to kiss your @ss goodbye.<br /><br />But please, lets not fool anyone on this or any other forum that there is a safe way to travel at speed towing a heavy, ungainly weight behind. It will always be a gamble.
