robbie42301
Thread starter- Joined
- Mar 6, 2011
- 17
Hey everyone, My name's Robbie and I just purchased an old boat to fix up. I'm not new to boating and have done quite a bit of work on boats, but nothing dealing with an outboard motor and nothing this old. I picked up a 1969 starcraft (Imperial maybe?) with a '71 60 Hp. Johnson. The boat has been sitting for many years and I am not really sure where to start. I am able to turn the engine over by hand and it seams to have good compression. I have not tested it with a gage though. It has the Hydro Shift (??) and the throttle lever doesn't want to move very far forward or backward. I did not try to force anything, but cannot get the prop to engage either gear. My plan of attack is to mix-up some fresh gas, remove plugs and spray lubricant into the cylinders, crank, replace plugs and test for spark. I'm sure the carbs will need to be rebuilt, and the water pump replaced, but what else should I address. Any info on the shifting of this engine or guidance to reserecting this old boat would be much appreciated. Thanks in advance!!
