Non-starting EVINRUDE 75HP 1965 Starflite VII
dcald
Help !<br /><br />After 1 days use this season, above motor refuses to start. Compression >100. Spark appears to be OK. Cleaned out carb, checked timing. Does not even fire.
dcald
Re: Non-starting EVINRUDE 75HP 1965 Starflite VII
Well here is some progress.<br /><br />I checked the timing again .... flywheel timing mark aligned to the mark on the engine case ... distributor wheel aligned to the button .... nothing.<br /><br />In desparation I tried moving the timing 90deg, then 180deg, then 270deg, at which point vrooooom ... off it went like the proverbial bat out of hell.<br /><br />Intrigued by this, I took it to the lake, and the boat worked the best is has ever done ... for about 15 mins then got all rough again. I moved the timing belt another few notches, and got it to run just as sweet ... for another 10 mins .... at which point it went out again !!<br /><br />So it appears that the timing is slipping out ... but I cannot understand why. Can the flywheel slip against the crankshaft ? Can the wheel on top of the distributor slip in relation to the rotor position ? It is not the belt slipping .... the relative position of the flywheel mark and the distributor wheel marks don't change ... but the setting of the distributor wheel that makes the engine run sweet does.<br /><br />Any suggestions ??
foxjohnc03
Pull the flywheel and see if you sheared the key. It would do exactly as described.
dcald
John,<br /><br />Great call !!!<br /><br />I hunted around all day for a flywheel puller. Didn't need to. Tonight, I took the flywheel nut off, sprayed some PB down the threads, two taps and it was in my hand. <br /><br />Oh, and as you suggested, the "key" was in several pieces !!! Before I took the flywheel off, I tried to "feel" what was TDC when the flywheel mark was on the timing mark. Yesterday, #4 was almost on TDC; today, well it was none of them really. <br /><br />Here's hoping .... I am convinced that this has been the problem all along. Thank you very much for your insight and advice. Can't wait to get a new key, and get back onto the lake.<br /><br />Douglas
Joe Reeves
Make sure the flywheel and crankshaft tapers are clean, and that you torque the flywheel nut to exactly 105 foot pounds. Neglecting this will result in a replay of shearing that key.
