Noisy lower unit / Rattle
papaterk
Hi gang,
I just made the move to a stainless steel prop and have a question. I did not experience any issues with the old aluminum prop. Engine ran fine with no noise and the lower unit grease drained out clean. After installing the stainless prop, I discovered a noise at idle in gear. It sounds like a heavy rattling, but goes away right after I increase the speed. The prop is obviously alot heavier, and this may be normal. The prop shop installed a new hub, and furnished a new thrust washer and retainer washer to put behind the nut. I torqued to 55 lb ft and tighted a litlle more to install the cotter pin. The prop has about the same in and out thrust clearance as the original.
Just checking to be sure I don't damage anything.
1992 60 HP Evinrude, large gear case.
Any help or advise would be appreciated.
Thanks, Pop
If you think healthcare is expensive now, wait till it's free!
Will Bark
Re: Noisy lower unit / Rattle
May be too tight; torque to the specs then back off one flat to install the cotter pin; same logic as on trailer axles.:)
