glastron11
Thread starter- Joined
- Aug 18, 2010
- 22
I have 2008 glastron, 5.0 with a sx-a outdrive. There is a rattling noise that seems to come from the top half of the unit. It is not where the ujoints are. It is not real loud but I need to see if there is something that is causing the noise. It is not a hard pounding noise, but a tin like rattling. I purchased the sx-a manual that shows exploded of all the components upper and lower. I took off the cover that is over the shifting linkage( 5 bolts) The top of the unit has a couple of bolts on it (also houses dip stick for the lower unit). Can taking this top off expose enough to see what is causing the noise? Can anyone help me step by step on this issue to check anything that would make the noise. I have another boat owner that is having the same noise.
