No water stream from my cooling system...HELP
doyle007
Guys, I have a 1996 Mercury 150 Offshore. I dropped the lower unit, took off the water pump housing, and replaced the impeller and gaskets. I also replaced the housing itself, but my new torque wrench (Harbor Freight job) did not click for me at the required 50 ft/lbs. Instead of looking, i was listening. The good news is that my old housing was in good shape, so I just put that back on.
So, the new impeller went back on with no problem. The woodruff key was installed, and matched up with the little indent on the brass part of the impeller ring. I'm assuming that there is no top or bottom to the impeller, as the vanes should move themselves to the proper configuration as the drive shaft spins (am I correct on this?). I got everything put back together, and the lower unit was reinstalled over the weekend.
Now, I just went out to start the motor to make sure that everything was fine. This is the first time that the motor has been run in about three months. I filled a rubbermaid tub with water, lowered the motor down into it, and the water level covered the exhaust hub (my neighbors appreciate this) and the cooling intake holes. It started right up, but no water came out of the little hole to show that it is being cooled. I waited about 30 seconds, and then turned it off. I felt the engine, and it was warm, but not hot. I gave it about five minutes, and tried it again. Same result. So, I try one last time. Exhaust and smoke came out of the weep hole (I was using Sea Foam to decarbon the engine), and finally it started to spit a bit. After another minute, a big pulse of water shot out, and then stopped. This repeated over and over. It was sort of like going to the bathroom, and pushing as hard as you can to get every little drop out before you start a long road trip. Squirt-stop-squirt-stop-squirt.......
So, what's my next move? I made sure that the little tube on top of the pump housing lined up with the metal tube on the engine. The impeller was new, the gaskets new, and I had ample water available for the engine to circulate. I stuck a paper clip in the hole to see if anything was stuck in there, and nothing came out. Any ideas?
basspro68
Re: No water stream from my cooling system...HELP
have you checked thermostats,that could be the problem---unless gaskets didnt seal
lil_jason17
was the old impeller missing any chunks out of it. Sometimes they can be sucked into the coolant passages and block the flow.
doyle007
Guys, thanks for the replies. I have not checked the thermostats yet, but I did see a small crack in the line that goes from the one thermostat to the other. I guess that this crack, even though it's small, could be introducing air into the water line. Do you think that this could be the cause of my squirt-stop-squirt-stop issue?
Also, the old impeller was completely intact. There weren't any pieces broken off that could have clogged the lines. As far as the gaskets, I'm assuming that they sealed, but I wouldn't have any clue as how to check for that. I did not use any kind of gasket sealant product on them, I just put them on in the proper order (using the old ones as my guide), and that was it.
I did notice that there are some holes underneath the horizontal fins that are just above the gear housing, and that water flowed nicely out of those holes while I ran the motor.
This is my first outboard, so I'm not exactly a whiz around them. I did some research before I attempted the process, read both the Mercury Service Manual on the process, as well as the Seloc manual, and looked at someone's post online that had pictures of the process. I believe that I did it correctly, so that's why I'm seeking any comments on what I should do. I really appreciate your input.
pancakes
give the thermostats a look. it's a 5 minute job and costs 20 bucks for a repair kit. if the cracks in your line we an issue, you'd be seeing water coming out not air going in. once the new stats are in, the motor has to reach 143f before the motor will pee. and even then it's not too impressive on my 150 efi.
j_martin
1. The hoses on the t-stat housing are discharge hoses. If they leak, they get the wiring wet. Has no effect on cooling.
2. There should not be any exhaust out the tell-tale under any conditions. You have a bad gasket or crack in the cooling system somewhere. You are getting exhaust gas in the water jacket.
Sorry for the news.
Hope it helps
John
doyle007
Guys, thanks again for the replies. I spoke to a neighbor that had a similar problem, and he said to try and flush it out using the garden hose flush port. I did that for about ten minutes, and for the first seven or eight minutes, the water pulsed out, just as it had when I was running the motor. The final couple of minutes, it came out in a solid stream.
I closed up the flushing port, and connected the hose to the ear muffs. I started the motor, and after a few minutes, a solid stream appeared. Another bonus is that there was not any exhaust smoke coming out of the weephole. I put a digital thermometer into a bucket of water that I collected from the weephole, and it read about 138 degrees.
So, I'm going to drop the boat in the water in about a week, and rest assured that I have a Tow Boat US membership.
