Re: No water from Tell Tale
Old Guy (grin)....... Even when the water circulation department is in ideal condition, those water tell tale outlets can become clogged if that outlet is the small plastic fitting. If so, with the engine running, stick a piece of solid mechanics wire up the fitting when it's running or remove the hose from the fitting to clean it.<br /><br />If on the other hand, you're speaking of the tell tale that is simply a water hose type outlet, then I'd strongly suggest that you drop the lower unit and re-check that water pump.
