usmcbucfan
Thread starter- Joined
- May 22, 2004
- 8
I hate to sound stupid here, but I have an older 50 horse merc that has been sitting for a while. Last time I ran it it had no problem with the water output (I'm not really sure what the technical name for that is so I'll call it a stream). however, when I started it up again, there was no stream. I replaced the impeller kit with all the gaskets and whatnot, there still is no stream, but now it is coming out of the exhaust. I took the lower unit back off and there was an extreme amount of sand in the water pump area. I tried to force water in through the water intake tube and it still had no stream, but it came back out of the exhaust. I also pulled the tube off of the top of the engine and blew through it and it seemed to be stopped up, but no water would come through the hole on top. Lastly, there was some water leaking out from the middle of the engine but not in a large amount. Once again, I'm new at this and I'm sorry if I sound too stupid. Thanks for any help you may have.
