no water coming from water discharge
slepthien
I have a 1979 johnson 6 horse. I replaced the impeller because there was no water coming out the water discharge. I am still getting no water out. Any help out there???
marinemech1
Re: no water coming from water discharge
dischrge nipple may be plugged. does motor overheat? if not use a paper clip or similar object to try to clear nipple
slepthien
I have cleared the nipple with a wire
chris in va
Did you make sure to install the impeller with the key that fits into the shaft? Otherwise the impeller won't move.<br /><br />Also the plug maybe further into the system, and I was told by the local Johnson mechanic to blow out the lines with compressed air periodically.
OBJ
Pull the indicator hose off the elbow on the engine and run a wire in there. You can also blow back through it with some air.
