no top end power untill you push choke in
Joe Reeves
Re: no top end power untill you push choke in
This is a 1988 Ford 302 V8, right? :)
Regardless..... the carburetor is fouled, clean and rebuild it.
mitts
150 hp evinrude 1988 i cleaned carb and put new fuel lines and plugs
Joe Reeves
Did you manually clean the six high speed jets that are located in the bottom center portion of the carburetor float chambers...... that is clean them with a piece of single strand steel wire? If not, do so.
Pushing the key in energizes the fuel primer solenoid which shoots fuel directly into the intake manifold. If fuel was flowing thru the carburetor passageways properly, you wouldn't need to do that.
silvano
Hello all i am new to this site and new to boating. Here is my weird problem last week i just bought this boat its a 26' ft cruisers merc 5.7 alpha one drive took it out to a local lake but before i went to the lake i made sure the boat would start so i hooked up my hose and ran it for about 5 min then i hooked up and left to the lake when i got there i backed down the ramp and it started then stalled i open the choke i thought maybe i flooded it still crank no start then pulled it out and quess what it started up then quickley shut it down so im back in line waiting my turn to unload get to the ramp back it down starts up and the same crap happens this time i crancked it till the dam battery die's lucky for me there was a marina up the road. bought a new battery popped it in and started again on land grrrrrrrrrrrrrrr. So here i am 3 hours trying to get this boat in the water so this time im on the ramp i start it before i get in the water back it down while its running im in the water had it reved up to around 1500 rpm stayed on the ramp till the temp rised a bit. Now the boat is finally in the water drove it all day (7) hours no problem. Now do i have a boat that thinks it a car? lol Y does it start on land and problems while its in the water also when i put it reverse it sometimes stalls.
Thank you all
mitts
yes i did clean jets in float do you think bad gas could have somthing to do with it 1 1/2 years old
AlTn
1 1/2 year old fuel no doubt contributed,but I'd follow Joe's advice were I in your position
mitts
still having problems i cleaned carbs, put new fuel lines , new spark plugs, and put new fuel in tank still no power till i push choke in this is a vro moter do you think this could have somthing to do with it
mitts
problem solved had to soak carbs in carb cleaner for two days rebuilt carbs and fresh gas running great now
