FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
Maybe someone already posted it and of so I'm sorry but my power tilt trim motor doesn't work, possibly broke and my engine is stuck and I need to lift it up. Is there any manual way to do this?
Are you absolutely positively sure the trim motor is not working? I recently had the same issue but when I hooked the wires directly to a battery it worked fine. I found a bad connection in the wire between the relay and the trim motor. One way to check this is to use a test light or volt meter to see if you're getting power to the motor when you engage the tilt/trim switch.
You haven't posted a year or model, but you may have a manual release on the starboard side of the tnt bracket. It would be a larger slot head recessed in a hole. Loosen a little and lift the motor up.
I don't have a battery right now the one that came with it is shot. I'll pick one up next week.
I found a very large screw fitting a flathead that i unscrewed all the way, nothing came out of it but i bet stuff should have :/ . this is a picture of one of my pistons (?not sure what to call it)
The manual release valve is on the side of the stern bracket depending on the yr. The screw you loosened has nothing to do with manually raising the mtr.
On the outside of the starboard(right) transom bracket there should be a hole and in it you should see a slot headed screw unscrew it about 2 turns and you should be able to raise your motor it may not be easy but it should come up. good luck
Thank you so much! I will try tomorrow if it won't rain that bad. Seriously busted up my skeg moving the boat when i got it due to it will not move. Anyone have an opinion about a new skeg?
Thank you Will Bark! Wish I knew that before i took it home last fall, broke the skeg and prop But it's now on the motor holding arm thing, sry no technical nature about me. thanks again.
