Rectifier was bad so i replaced, battery charging good now. Tach was not working, was hoping rectifier replacement would cure, no luck. Have 12 volts at ign terminal on tach at key on position. On tach terminal (gray wire from engine) have zero volts at off, 6 volts and change when running, no increase(or decrease) when throttle changes position. My guess is bad tach. It is probably original to boat (1987) or motor ( 1996 johnson Special 88) Anyone have any input. Oh yeah, engine has a higher idle(by my ear, no tach) since i changed rectifier.
