No start no crank at times
Brian Stillwell
Please help I have spent over $2000. Dollars with 3 dealers trying to solve this problem. I have a 03 225. e225fpls1m. What happens is that I can be running at part throttle and boat will shut off like someone turned key off. It will not crank the lights prove out, then the low oil/temp/ engine light will come on and stay on. No fuel pump running will not crank. May wait 10 to 20 min restarts everything fine. may not happen again for days or in 30 min it will happen again. Also may run to a spot everything is fine shut down engine and maybe need to fire back up in a short time and same thing happens. dealers have changed fuse box, oil injector pump, capaticer,diff. realys. now they want $1100 for a ecm. HELP!!!!! No codes are stored when this happens and the boat has never not restarted. Seems to happen more at extended idle speeds or mid throttle running.. Thanks for any help. Brian
tashasdaddy
Re: No start no crank at times
this is a FICHT motor isn't it. can't help you.
