FreeBeeTony
- May 15, 2002
- 3,991
Verified spark at the coil wire and fuel in the carb!!
What could have changed overnight?
Thought of another possibility.
When I 1st diagnosed the "No spark" condition I did so by putting a screwdriver in the coil wire and placed the screwdriver over the center of the distributor.....no spark observed...spacing was ~1/4" or more.
FreeBeeTony said:Now using a spark plug in col wire to check for spark......spark is present but now suspect "weak spark" condition.
Spark was yellow/orange......S/B Blue???
FreeBeeTony said:Going to pick up this adjustable spark tester tonight.......how far should the spark jump?
FreeBeeTony said:If it is in fact a weak spark......what would cause this?
FreeBeeTony said:
Engine does not start.....
What is the peak voltage of the TBIV system?ā
If that's the case, then using the spark tester I should set it for 30KV..........
