No spark
KevinKennedy
I have a 1993 evinrude that's not putting out spark. I've replaced the ignition switch, cdi pack, plugs and wires. Motor cranks strong but will not produce spark. Any suggestions on what to check ?
emdsapmgr
That engine is an 89, based on the model number given. There are two additional critical ignition components, the timer base and the stator. One or both could be part of the problem. This website has some excellent ignition troubleshooting info: cdielectronics.com. Both devices can be checked for cranking voltage output, as per CDI. You will need a special "peak-reading" voltmeter.
Will Bark
Are you sure that the battery is strong enough to spin the engine at 300 rpms? May want to have the battery load tested at auto parts store.
KevinKennedy
Thanks guys, it has lanyard and the battery is good. I will get the stator checked ASAP
Foxstan
What type of ignition switch did you use and did it work before that? Was it one rated for use with an outboard? An automotive ignition switch will ground the coil so there would be no spark.
KevinKennedy
It is a switch for outboards. When I changed the cdi pack it tried to start twice and went back to no spark
